joy stick control
lerrad16
Member Posts: 5 ✭
can I install the merc joystick in my 2002 6.2 twin I/O
lerrad16
Member Posts: 5 ✭
it would be cheaper to buy a new boat
A guy made one out of a Wii controller i believe. If you are skilled with servos/programming you can do this.
He did it so his kid could operate his boat.
Im not sure if boat compaines had this set up for sale before or after his boat went viral.
He built his from scratch.
In practice, almost nobody installs joystick retrofits because it's such a huge and expensive job. Different helm station, shifters, steering, on and on. As @zaverin1 said, it's easier and cheaper to buy a different boat.
Depends on your ability. The motors out of a windshield wiper are pretty strong.
This isn't the video i wanted but its full diy. The guy i spoke with built his inboard using parts from electric scooters, he sales/services them so he already had access to many of the parts.
nintendo joystick and some
garage parts are totally different from the actual system merc uses.
i mean of course you can make it work but how reliable is it going to be.
The controller should be kept out of weather and spares kept in case of weather.
As for the servos/motors and wiring, if you use marine/outdoor quality proper sized stuff it will be reliable. Use under sized cheap wiring, eBay cheap china servos and motors it will be good for a prototype.
We already have access to marine servos and motors whether its for auto helm, windshield wipers, windlass, etc. Installing circuitry in a sealed container will be a must.
build one
I did find that there are waterproof joysticks where a video game controller doesnt need to be used and you can program each drive to run independently on each stick (with an rpm and/or speed reverse lock out) or run them both on the same joystick. Being that it would be run like a drone you could also do things like operate via Wi-Fi/blue tooth using an app to operate the boat by a phone/tablet as well as features such as cruise control (throttle/speed lock) and even an auto helm feature with single or multiple check points.
Basically you could make your boat operate as a drone.
If anyone wants to bank roll this lol.
i do Plc and CNC programming.
to build what you described would cost 10k just in components not including custom fab and programming.
so let’s say 35k
Are AtMega chips difficult to program to communicate back and forth in real time?
Here boys, hold my beer while i work my magic
If your boat isn't already set up for the joystick control, I would have to say that it would not be feasible or practical to attempt it. For one, I believe there were no consumer grade joystick boats in 2002. I'm am guessing 2006 was the time when they began to hit the market. So you would most likely need to find a computer module from a later year boat and then "try" to integrate the software and hardware into your application.
There is a lot more to having a joystick than just buying one and hooking it up.
Another alternative for you to consider is a "Yacht Controller" system. It is a handheld remote that will act like a joystick for docking. They will most likely have a system to fit your needs but be ready for sticker shock. I also believe that the system requires a bow and stern thruster. Something the company can provide during the install process.
Good Luck !
The most programming i do now is settting carb fueling stepper motors back to factory specs after a rebuild.
Visual basic programming was a lot of cut and paste
Cisco computer networking was a little more fun. The more computers we linked the more people we could play against on doom.
