Gen 2 Cool fuel pump on 2000 Rinker 340
Bill_CeaseBill_Cease Member Posts: 8
Hey Everyone,
I am running in to an issue where one engine will not develop more then about 2800 RPM's and that is it. I cannot even get the boat up on plane with one motor doing all the work. I guess technically I have a 2 part question here.
1. I have what appears to be a sensor threaded in the block (As you are facing the motor) it is on the right all the way to the back and just above the oil pan. It has one single wire that is light blue. I have read that this could be a sensor for oil pressure and that if it fails it will limit RPM's. It is corroded and I have removed it but was wondering if anyone had any insight. I checked with a shop and they told me they would need to see it to tell me what I needed to replace.
2. While replacing plugs, wires, and running a compression check I was trying to locate the fuel pump on the engine. Does anyone know if I am correct that it appears (Again facing the motor) that it is on the right side to the front of the motor. Unfortunately it looks like that on the 340 that I may actually have to have the motor pulled to get to it. Just want to know if this is true or is there a work around to replace the pump if I find that is the issue...
Still working on it and starting with the basic's since the scan tool shows everything being normal...
Thanks again,
Bill
  • bnallobnallo Member Posts: 2
    Bill,
        Did you ever get an answer to pulling the engine to replace the fuel pump? Running into the same problem on my 342. She runs up to 3K on the SB side engine and thats all she'll do!
     Bill Nalllo
    Did you check your throttle to make sure that it is going to wot could be a possible adjustment problem
    Yes doesn't seem to a throttle adjustment problem.
  • CrewLoungeCrewLounge Member Posts: 92 ✭✭
    That sensor is your oil pressure sensor for your guage
  • mihalekmihalek Member Posts: 8
    I'm having the same problem with my port motor. 3000 rpm is all she'll go under load. any resolutions?
    Replacing the high pressure fuel assembly was the answer to the problem that I had on my port side motor. The mechanic was able to replace the unit without removing the motor. Back up and cruising again.
    Always nice to hear "back up and cruising again".
    Did you try pulling both engines from the starboard tank?
    Sin or Swim - Rinker 312
  • scottb3200scottb3200 Member Posts: 46 ✭✭
    edited August 2014
    Same thing has happen to my 320 with Mercruiser 5.0 MPI  both engines won't go over 2600 rpms I found paint in my fuel regulators on the fuel pump module filters are clean paint came from module I clean the paint out of module and change regulators I have 40 psi on rail the regulator on the rail is clean but still not able to get rpms over 2600 rpms bottom is clean need help any ideas
