help me please
I am having a few electrical issues. my boat was in the slip and the shore power breaker tripped resulting in dead batteries. since then my horn and spreader lights do not work. no fuses are popped. any ideas. is there another area to check?
Did you get a meter and check for voltage at the breaker, switch and fixture like Boomer mentioned?
If your horn and spreader lights quit working after the incident it sounds like an odd coincidence and I'd bet that Boomers right about it being a corroded contact or switch failure. Either way, getting a tester on those switches and fixtures would be the 1st thing to check.
It might be relevant to post what year and model boat you have so it can be narrowed down by those with a similar boat. That's all I have. Good luck, Mike
