generator instal 280ec
getting ready to install my generator but i don t feel to good about making a hole at the bottom for water pick up  i was told i could put a t connector on my water pick up from my motor to supply water for the genny  is this a good idea has any one done this ?
  • aero3113aero3113 Member Posts: 9,684 ✭✭✭✭✭
    edited March 2020
    I wonder if you might get less water to the generator or motor if both are running at the same time. If you run them separate, might not be an issue.
  • Cableguy GregCableguy Greg Member Posts: 5,070 ✭✭✭✭✭
    I would say it isn’t a good idea. I would want a separate pickup for the generator. Make sure you seal the hole with 5200.
    What kind of generator did you get? Where did you get it? I have a 280EC and would love to add a generator. I have a portable one, but a built in one would be a game changer for me. Be sure to post pictures of the installation.
  • tazdeviltazdevil Member Posts: 45
    hi cable guy
    got a 3 kw onan with 37hrs here in canada actually in ontario getting checked by a friend who works at onan
  • rasburyrasbury Member Posts: 8,874 ✭✭✭✭✭
    I would think the thru Hull would be the way to go...my 270 has so many friggin holes in it, what's one more...
  • Dream_InnDream_Inn Member, Moderator Posts: 7,877 mod
    I agree, you need to do it correctly with its own thru hull.
