Aluminium or Bronze Prop?
Hi all, I need to get a new duo prop for my 270FV with that has a Volvo D4-260 Diesel engine but not sure whether to get Aluminium (£600) or Bronze (£1600).
The price difference is significant, is there a downside to Aluminium?
Appreciate some opinion or advice
thanks
    Man with the good looking 270. I looked at your profile and was trying to find if your in salt or fresh?
  • MissLee2005MissLee2005 Member Posts: 67 ✭✭
    It spent the first 14 years of its life on fresh water cruising up and down rivers, but for the last year (since I’ve owned it) and from now on always Salt water
    If were mine it would be SS. here is an artical on bronze.
    https://www.passagemaker.com/channels/dont-fall-for-the-brass-line
    Thanks interesting article, boils down to this
    £600 Aluminium
    £1500 Bronze
    £2000 SS
    Woof, do you have a B3 ? Are your other prop's bent up or bad. They can be rebuilt.
    It’s a duo prop set up. The previous owner bored out the internals to fit new bushings but they have are now destroyed which has left the prop unrepairable.  Max speed 7knots@3500 revs
  • PickleRickPickleRick Member Posts: 4,140 ✭✭✭✭✭
    If on a budget id buy aluminum then save for the stainless.  Keep an eye on the used market for a set.  It costs about 60 bucks a prop locally to repair knicked up fins. When you get the stainless keep the aluminum for spares, spare props are great to have.
    I don't mind aluminum in light boats, your 270 is not a light boat, but it will work.
    Thanks picklerick...what about Bronze?
    Bronze im not familiar with.  Id also ask my local prop shops if they have experience repairing bronze props before id buy.  If they don't seem up for the repair, avoid them.   You will eventually get knicks in your props and need them serviced.
    Aluminum and stainless are the go to in my area.
    I have a set of 22's SS on the shelf, from when I upgraded to 4 blade, come on over I'll make you a deal.
  • WillhoundWillhound Member Posts: 4,220 ✭✭✭✭✭
    It's a Volvo Randy. I searched them and even in the States the Aluminum for $650USD and up a pair.
    Is a Volvo d4-260 diesel. £600 Aluminium or £1500 Bronze or £2000 for SS.
    shes kept in salt water 100% of time so I think Bronze is going have to do
