Sticky Throttle and Steering Play
Hi everyone, hope you're all staying safe and getting a chance to social distance on the water.
I'm still putting work into my 2001 270 FV, replaced the VHF antenna and head unit today, working great! Next project is to tackle the horrible throttle and loose steering.
I have a 383 Stroker with a bravo 3, it has what I believe to be the original quicksilver throttle currently installed. It's super harsh to shift gears, I took the throttle control apart today and it looked and felt like some of the internal components were just worn out. I'm looking at this unit for the replacement: https://www.marineengine.com/products/accessory.php?in=3463502(not necessarily that vendor, but the model looks good) and had a few questions:
-Do you think I should change out the shifter and throttle cables as well? Is there a way to check if that's required or if I can get away with what I currently have?
-Anyone done the swap before? Anything to be careful of? The IOM for the seastar looks pretty straight forward.
For my steering, I have a rack system. There's currently about 5 inches of play when I turn the wheel in the opposite direction of my last turn til it responds. I had the dash apart today and noticed that the end of the rack that the cable comes out of sort of bulges when I'm in my dead zone, I'm planning on replacing the whole thing. Problem is it's super hard to get to even with all the dash panels off, so I wasn't able to get any model numbers or lengths for the cable, etc.
-Does anyone have any model numbers or resources I might be able to use to find a rack and cable length for replacement without pulling it all out first? I can remove it if I need to to get part numbers, but thought I'd ask first.
Any other thoughts you might have based on what I've described is always appreciated as well.
2001 270 "Salty Disposition"
I also ordered new throttle/shift cables for my 330 but haven't installed them yet. I emailed Rinker and they provided me with the lengths so that I wouldn't have to remove and measure.
I replaced the binnacle, shift and throttle cables in my former boat and it was easy to do and made a huge difference.
The other thing to know is that you need the control with both trim and tilt if you want to be able to fully raise the outdrives.
EDIT: I found the install doc that the Seastar tech sent to me to clarify. I also attached the wiring diagram for the trim and tilt.
If I remember correctly, you want to connect the violet to the trim (not blue as indicated in the diagram above) and the blue to the tilt.
Here's the contact info for the tech that helped me:
Jim Corday
Tech Support Rep II
Phone +1 610-495-7011
Jim.Corday@dometic.com
69fastback, I actually already replaced the transom assembly, first thing I had to do with the boat. Started sinking on my first time out haha. I'm looking at one of the helm and steering cable kits similar to this: https://www.marinepartssource.com/ss141-rack-and-pinion-steering-kit
Just need to get the cable length when I'm there this weekend doing the throttle control.
The steerimg cable was SSC13416 if anyone needs it for future reference.
Drives and shifts like a new boat.
