My first launch sucked!!!
PickleRick
Member Posts: 4,371 ✭✭✭✭✭
Launched, ran approx 100 yards and saw the temp gauge spike to 190. I have a brand new thermostat, water hoses, impeller installed. Also new manifolds and risers(oem) Went to restart after cooling down and engine is locked.
Broke off a starter bolt.
Several cyliners were full of water on each side of the block.
My theory thus far:
I sent out my foot to have the skeg welded.
He was supposed to reassemble with new impeller.
Im wondering if he welded it with impeller installed and fried it?
Then my running on muffs burnt out the flappers in the exhaust.
When temps spiked and i killed the motor the flowing water pushed back into my manifolds thus filling cylinders. Cooking riser gaskets is also a possibility.
I removed the thermostat to find the intake still half full of pink antifreeze. At 190 the 160 thermostat should have opened and fresh water flushed it out.
Got the bolt extracted last night and starter rehung.
Cleaned and sprayed cylinders with lots of wd40. Turned it over and repeated several times.
Am about to do a compression test and remove risers to examine gaskets and flappers.
Fingers crossed this isn't new motor time.
My theory thus far:
Compression on 7 cylinders right at 200 to 210 and the number 8 cyliner is 180. Pretty much confirms my theory that she wasn't taking water into the cylinders while running.
This is a cold reading. I believe on raw water cooled motors number 8 is the one that runs the hottest and gets the most wear. I'm tired, sunburnt and frustrated so the memory bank may be fuzzy this morning.
Now I'm pulling risers for inspection.
I told the admiral that im still getting to spend the weekend on the boat.
I didnt run it very long as its best impossible to get up to temp on muffs. I have now rigged up a large tote to run my motor in.
I maybe i blew out the flappers? Maybe they were not in there to begin with. I didnt know there were flappers in the exhaust until this happened. I also found i ran all last season with the shift interrupt switch disconnected. This boat was previously owned by a dude with a boat.
I ordered new oem flappers, y pipe bellows and riser gaskets. I also bordered a new oem impeller.
Once i have her reassembled i will run her to see if shes pushing water up to the engine. Will also be picking up some new spark plugs later this week.
I keep telling myself the water is too cold to enjoy anyway.
Port side flapper(what's left of it) on the carb cover
The starboard side is gone.
I'll need to bring home my bore scope to see if any parts must he fished out of the bottom of the y pipe before reinstall.
While rebuilding the transom i moved the y pipe around a good deal and didn't hear or feel anyting rattling around in it. Whish i had known these where in there and this would have already been dealt with.
Block should be fine. Now i need this foot to work with me and go back on.
I hope these parts arrive soon. Next Friday is the admirals b day so i dont see any lake time.
Got a lead on a 97 model vortec 5.7 just in case. I won't be off the water long.
Rick- that bites, man. sorry to hear.. did you put the leg on or did mr. welder guy?
those flappers were lost because the combustion heat hit them without the benefit of water being dumped just before them in the elbow. for what it's worth, i've ran boats often without them- so long as you outrun the wave as mentioned before, AND, you don't expose your stern to others wakes or waves from tides, you'll be okay almost always..
when the risers are as hot as they must have been that heat is almost like a vacuum when you stop drawing water in the form of steam toward them, and then condensing as it drips back down the runners- finding an open exhaust valve.
and.. as things cascade, when a flapper breaks it becomes an obstruction, which will spike your engine temperatures..... just like a clogged catalytic converter will do.
It was a holiday weekend and i took plenty of wake to my stern and the manifolds were too hot to touch. I also had the wind at her stern for most of the time we were drifting.
While i had my foot off i got a good look into the exhaust and could see into the y pipe. I didnt see any signs of flappers. I will bore scope it Tuesday. I have one of those open ended exhaust bellows that only mate up to the leg when she's lowered.
Im kind of under the impression i had no flappers last year. I did have some carb issues last year wheh i first launched but she never left me stranded, she stalled out a time two and was a pita to restart but i guess i was fortunante she wasn't over heated at that time.
@212rowboat I always try to do this also.
