AC louver in head is broken
The toilet seat hit the little round AC louver and broke the louvers off. Any thoughts on where I can get a replacement?
BTW, access is from the shower. You have to pull the shelf assembly out of the shower and then do the old bend your body around, hold your face up against the shower wall and blindly feel around with one hand.
Capt Steve
Below are pics of the AC head louver on my 2006 342. The piece is about 4 inch diameter with two louvers, one of which is broken off. The pin that forms the hinge for the upper louver is broken so I need the entire assembly.
Thanks,
Is the louvre actually broken? A slip mate told me his "plastic" round louvre deflector in the head had broken. It had not. There are small plastic pins on the movable louvre"flaps" that I snapped back into position for him. I did have to apply some pressure to do it, that is why he thought it was broken. Then I suggested that he angle them either up or down because if you leave the "flaps" facing straight out the toilet seat will pop the louvres out when it is raised and hits them straight on. Rinker should move this louvre out of the way of the toilet seat - a simple engineering mod. MT
I Just Googled Marine Air Condition Vents a lot came up here are a couple
http://www.rvplus.com/d-and-w-register-round-4-dampered-white-3840rwh.html?CAWELAID=600008500000044467&CAGPSPN=pla&catargetid=600008500000242911&cadevice=c&mkwid=hyIbjxSA&pcrid=54734727768&pdv=c&gclid=CLqeg7LKpMACFSMV7AodiRQAOg
http://www.marinepartssource.com/newdetails.asp?mfgno=R4AOW&pnumber=MSIR4AOW&mfg=MSI MARINE SYSTEMS INC&desc=4 In. Off White Round Damper Vent
That was just an example Just Google it's there someplace here's one all sizes
http://www.ventmastersstore.com/small-round-vents/?gclid=CJKh7afhpMACFc1i7Aod-CcAbg
