Gear ratio and prop pitch Rinker 270 2001 RNK69111G102 Mercruiser 350 Horizon
Andrew23345Andrew23345 Member Posts: 2
Hello. I got stuck on the problem. What my boat came with from the factory in terms of  Bravo III gear ratio and prop pitch?
    Should be a 2.20 B3 and 22 pitch prop.
    Have someone turn motor over by hand and you watch the prop, motor turns 2.2 to the prop trun once. 22 pitch is about as much as the 350 horizon can push the #7250 270. If you are looking for better hole shot and lower plane speed look at Hill Marine 4x4 props $1100.
    Oh and welcome to the forum.
    BTW, if that is your HIN, you have a 2002 270 Fiesta Vee.
  • Andrew23345Andrew23345 Member Posts: 2
    Thanks for the consultation
