Power Supply for TV Antenna Gaincontrol/Booster
Willhound
Member Posts: 4,243 ✭✭✭✭✭
Installed one of these on my arch yesterday:
http://www.glomex.it/leisure/eng/antenna-tv-V9125-12.php and managed to get the coax routed to the TV. It uses a small signal booster/gain control that requires 12V power. According to the specs it draws 20mA. My quickest and easiest source is to splice into the feed for a 12v accessory outlet located right at the TV location. Easy peasy.
Should I be concerned at all that the draw on this is continuous? Doesn't seem like much draw. Could install some kind of toggle switch I suppose.
