Battery charger appears to be not working
Spyderweb
Member Posts: 951 ✭✭✭
While up at boat yesterday to do some work, I figured I'd hook up power so I could charge batteries after long winter. Ran power cord to boat and turned on charger breaker. I noticed volts for the house bank showed 12.0 at the meter on the electrical panel. Kinda low, but I figured not unexpected after winter.
When I got ready to leave about 3-1/2 hours later, the panel still read 12.0 volts. Figured it should show some gain. Went into engine room and both house batteries were about 12.2, a typical differential I have got in the past between gauge on boat and actual check at battery. I also noticed a 3rd battery (for engines) was only 9.5 (that's not good) and the 4th battery, behind the generator was around 12.5, but wasn't even hooked up. I also noticed there was some corrosion on several of the terminals that I've never seen before, but didn't have time to clean it up.
I have an Inteli-Power Charger, PD-2130. The screen flashes through "output voltage" for each of the 3 banks, and they were all around 14.3 (as expected), but when it flashed to "Current" it was "0.0". I assume that means there was no charging going on. Would that have anything to do with one battery not being hooked up, or one battery being near "dead"? Or will poor connections cause this? Or is it a sign I need to replace this original charger?
@Cableguy Greg @Dream_Inn I was looking at the installation directions online to familiarize myself. Most of the wires on the PD-2130 appear to be a direct transfer to the Pronautic. There's the 3 DC red outlet wires plus Black ground coming from the center of the PD2130, and 3 AC wires (2 black and 1 white) coming from the right side. In the Pronautic directions on page 25 it shows a "case ground" on the left side. Is that something that is on the PD-2130?
https://www.promariner.com/en/~/media/inriver/365008-38505.pdf
