Shower Sump 400 EC
Can someone tell me where the shower sump Is located on my 400EC? Also, if it is leaking would it go into my bilge?
2008 Rinker 400EC Longport NJ
  • Dream_InnDream_Inn Member, Moderator Posts: 7,857 mod
    Aft cabin, port side, open closet door, underneath.  If I remember right, you have same year as mine, so you need to remove bottom floor panel access in the hang up closet. Yes, overflow will go into mid cabin bilge.
  • TonyATonyA Member Posts: 93
    yes 2008, I vacuumed all the water out of the bilge last weekend and by the end of the day the bilge was full and pumping water out of the side. Cant figure out where it is coming from. No rain but did run the Humidly control for about two hours at the end of the day to see how it worked.
    Which bilge?  Engine room or under mid cabin?  Mid bilge could be leak from fresh water, seacock, AC flow, shower sump, or AC condensation.
    I dried the engine bilge, the mid bilge which drains slowly into the engine bilge and the galley area where the fresh water tank is and all three were wet at the end of the day. My fresh water tank is empty.
