Steering pin/transom assembly moisture
Does this look like I have a leak or is this normal? Is the white stuff corrosion?
Thanks all.
Thanks all.
Patrick
06 Rinker 270
06 Rinker 270
06 Rinker 270
06 Rinker 270
http://jrmarine.com/videos.htm
06 Rinker 270
It's not an easy job any way you attack it.
06 Rinker 270
Bad looks like this or worse. It should be square.
06 Rinker 270
At least one of my steering pins is leaking. Maybe both. I just did transom assembly work (bellows gimbal etc) over the winter and sadly the tech did not note that the steering pins should be replaced.
