Solar Panels
YYZRC
Member Posts: 5,542 ✭✭✭✭✭
Looking for thoughts on a solar panel that would help keep my house bank powering the fridges. Will use genny as needed for bigger stuff. I would be mounting on the arch.
Thanks!
I have less than 250 in the set up. Ebay solar panel and controller.
Solar is my only charging in the sailboat. The motor runs off a dedicated battery.
I run a near identical panel. Used on 2 different sailboats and have another for the 2859 im going to get.
Controller i use to monitor the panel, keep it from discharging batteries when dark and prevent over charging.
Typically you'll get 150 or more cycles from the battery bank using 20 to 50% of your powers capacity.
Don't do this with starting batteries
https://www.amazon.com/Giosolar-Flexible-Monocrystalline-Photovoltaic-Controller/dp/B0859DD6DR/ref=sr_1_3?dchild=1&keywords=giosolar&qid=1593830623&sr=8-3
i highly recommend solar panels for this application... newer tech solar panels (which aren't as easy to find as you'd think as the chinese want to sell all their early generations stock piled before they flood the market with the good ones) are flat out amazing...
the 'new' tech experience i had was with military equipment- i don't know that they're something that is commercial off the shelf except for those who really REALLY want them they are so cost prohibitive.. the rumor is it's all about dumping the old tech before launching, full scale, with the better ones- or- charging a stupid amount for the new tech to cover the cost of getting rid of the old stuff...... you can't (or aren't supposed to) just toss a panel in the garbage... they start fires or electrocute people...
the new tech seems almost (to me) to have a surface on it like the old polaroid film did... not as squishy/pronounced, but something like it.
@Alswagg - tricky question... IF your guy uses a domed or 'pliable' panel that gets good exposure for, say, 6 hours- it would keep topped (tend) the batteries with 50~100w pretty easy... that's considering it's producing perhaps a third of the wattage for 2/3 of the time, and full wattage for a third of the time... if you had a 150w~200w panel that only got good exposure for an hour or maybe two due to placement? not as good...
you 'can' choose panels that 'overcharge'--- they have an additional cell that provides more voltage... like cramming 24v through a bulb rated for 12v... bulb won't last as long- like, maybe 10% as long- but for the amount of time it does? that rascal will be bright... so if on a flat surface and with only a short(ish) amount of time to charge- a 24v or 28v panel stepped down with either a potentiometer or a diode to 16v will flat out rush that (those) batteries with charge and perhaps charge it just as much as the panel with 6 hours exposure... be mindful what 'kinds' of batteries you're charging like this, though... some may not appreciate it, and that 'overcharged' light bulb at the end of it's life comes back to mind.... you can certainly touch 15vdc safely with most batteries... and get a good 'charge' not just a tend....
i stepped that one in the image to 16v i think it was... and ended up dialing it back to around 14.5v... i got/get plenty of exposure where i am (geographically).
some controllers are smart and actually sense when all the cells are producing, and what they're connected to- and throw everything they can at the batteries WHEN they can, and shut off when they could be a liability...
start poking around them a bit and you'll find precisely what you're needing...
there is a guy living near me who took the top off his 36v golf cart and formed a solar panel to it- you can hardly tell it's there- ran wires down the 1" tube stock of the tops frame, through the fiberglass body and to his battery's main block... stepped a 72v array to 44vdc, and keeps his cart fully charged rarely plugging it in. wanna guess where i got most my intel about these things from? heheheheeeee
https://marinesolar.com/sunpower-semi-flex-kits
