232 Captina fuse box location
Boltzie42Boltzie42 Member Posts: 9 ✭
Where are the fuses located on a Captina 232 BR and does anyone have a key?
Also, where is the blower located near the engine?  My blower stopped working but the switch lights up.  Tried resetting it to no avail.
any pictures are appreciated.
Danny
    The blower is mounted on the transom just above the fresh water tank.
  • Boltzie42Boltzie42 Member Posts: 9 ✭
    How about the fuses?
  • RiverRat232RiverRat232 Member Posts: 596 ✭✭✭
    Each device has a breaker right next to the switch. The engine breaker is the red button on the top on the engine above the port riser on mine. The location of that may vary by year, though.
    I had a 98 232cc and there was not a fuse panel. There were circuit breakers next to each switch at the helm and some of the circuit breakers power multiple items. My bilge pump circuit also powered the memory on the radio. When I had the pump go bad, I lost all of the presets.
