Slightly Bent Skeg
YYZRC
Member Posts: 5,366 ✭✭✭✭✭
I noticed that my starboard skeg is slightly bent/twisted. Maybe 3/8" bent and 3/8" twisted at most. How strong is the skeg - can I grab it with a vice grip and twist it back? Bang it with a mallet? Should I heat it with a propane torch to make it easier? Or do I just leave it to a pro?
My skeg was welded without removing the guts from the foot by an old timer doing prop repair and skeg repair in his garage.
Your marina may require tear down to repair.
If perfomance isnt an issue id address this winter.
This won't snap the skeg and will get most of the bend out.
@aero3113 has never repaired/replaced or messed with anyting that isnt broken😄
I may be guilty of the same, although to a little lesser degree
Ladies and gentlemen -- put your hands together for the Slightly Bent Skegs!
