212 Captiva 2005 Instrument Panel Access
I never had a boat until now that has the panel completely enclosed on bottom; how do I access to change out a gauge? Can someone lead me to a post or drawings or instructions somewhere? I cannot find anywhere online.
Best Answer
212rowboat Member Posts: 2,593 ✭✭✭✭✭
i wager it's some sort of seal created... either intentionally or accidental- like wax build up or something...
you 'can' access from the waste bin hatch... pull the can out and you should see a break in the fiberglass molding that allows you to better see what's going on in there... you won't be able to reach it, but may be able to see...
don't forget you can take out the switch panel too- allowing better access to the gauges as well... i usually lower my steering wheel's tilt and lay the switch panel across it when i'm working under there.
But I also pulled the lousy pull connections off of my voltmeter and have no idea where they go now. I've searched for pin connections but can't find any. Anybody got help with that one?
