Rinker 350 Electric issue
2008 Rinker 350 Electric issue.  Wife was using hair dryer at same time as hotwater heater and blew breaker at dock pedastal.  Reset pedastal and everything worked fine except the AC 110V plug at the cockpit bar.  I pulled garbage can to see and it is only the romax and a connector.  It does not even share same lline as the fridge and ice maker which each have their own.  It is not getting power anymore.  I checked the breakers on the panel for starboard and port plugs and all the rest work in boat work.  Is there a dedicated fuse\breaker for that cockpit plug hidden somewhere?  I have to believe it is off same breaker as other AC plugs.
    Does it have a GFI reset button on the outlet?  Press the button and re-check ...
  • Mich350Mich350 Member Posts: 19 ✭
    No gfi
  • JimGuy341JimGuy341 Member Posts: 108 ✭✭
    Any chance the GFI near the galley sink is tripped?
  • aero3113aero3113 Member Posts: 9,899 ✭✭✭✭✭
    Yea, check all the plugs. There’s probably a GFI on one that might need to be reset.
  • PickleRickPickleRick Member Posts: 4,380 ✭✭✭✭✭
    No gfi by the sink?  In my bayliner in lose all outlet power when the gfi by the sink is tripped.  All of these boats are built to a safety code, i thought outlets by any sink required gfi
    Hello everyone.  Got back to this today.  The bar sink in the cockpit is on same gfi as bath plug down below.
    So resetting the GFI fixed the problem?  Good to hear it.
    My 342 was the same, galley or head GFCI would trip and other outlets around the boat would not work and it took a while to realize I just needed to re set those two darn GFCI's. Glad all is well
    Took me 3 days to figure out why my 110 outlets didn't work on my new boat.  All i had to do was reset the gfi by the gally sink.
