Dry Bilge Solution?
YYZRC
Member Posts: 5,480 ✭✭✭✭✭
$400 isn't cheap, but...
https://www.youtube.com/watch?time_continue=3&v=tKFqp3Whonc&feature=emb_logo
The sponge Im thinking will suck up residual water to allow the pump to suck it dry. Going to try it out.
So I tried it out. In my prototype the sponge caused the pickup to create a ton of suction,. but so much suction that it hurt the water flow as the pickup was being sucked against the bottom of the bilge. I removed the sponge completely and the pump seemed to clear the water quickly leaving nothing behind.
I also want to play with the idea of a rigid tube mounted at the rear of the motor going into the lowest part of the bilge and see how that works.
Not bad for $29.95, should easily pump water.
Geelyda Oil Change Pump 12v 60w Fluid Diesel Fuel Extractor Suction Transfer Pump for 5L Boat Car Motorbike Transfer Pump Change Kit https://www.amazon.com/dp/B07CNYWQGK/ref=cm_sw_r_cp_api_i_m3YfFb8AWP91V
