Cabling problem -- Cableguygreg???
You may remember that I posted a few weeks ago about a problem that showed all the signs of being a failed house battery -- well, it wasn't! Briefly the situation now is that after much investigation and cursing it seems that we have lost a battery neutral somewhere and if I strap directly across from the house battery neutral terminal to the busbars that are located on the starboard side transom in the engine bay everything works as it should with no problems. The neutral cable that leaves the battery is larger than the one that arrives at the busbars and I assume that "somewhere" in between there is another connection, but without pulling all of the wiring apart in the engine bay, I cannot find where that might be. Does anyone know where it is? This is on a 2008 280ec.
