Ecovac Vacumm Toilet system
I have a 350 Rinker with a Ecovac toilet system. Should I leave the flush toilet switch on all the time. When I do the discharge pump (I think that is what it is) stays on and does not shut off. It is located under the trash can right by the ice maker. I just bought the boat and not sure if this is normal. Thanks
  • LaReaLaRea Member, Moderator Posts: 7,953 mod
    Yes, you should be able to leave it on all the time.  If the pump keeps running, it means there is a leak somewhere that is preventing the vacuum reservoir from pressurizing.  Take a look at the valve inside the toilet bowl.  Is there something keeping it from sealing?  Maybe some debris or mineral buildup?
    Welcome to the forum!
  • mfritzmfritz Member Posts: 41
    Thanks for your suggestion. The forum has been very helpful.
