Excessive Gear Lube
Remembrance
Posts: 30 ✭
Our 6.2L Mercruiser is using excessive Gear Lube and empties when the boat sits. An average day on the lake requires that I fill it twice and the remainder leaks out over night so that it has to be refilled each time the boat is used. Last year I don't think I used two containers all year. Are there any suggestions out there?
Get a bag... trash bag... white preferably... put your outdrive in it (or it around your outdrive foot as high as it will reach) and tape it... fill your reservoir and walk away.
For the love of all thats holy dont forget its on there...
Come back and carefully remove the bag... slide it off quickly and grab the top to secure it as fast as you can... lift it a little amd inspect its contents... hope for nothing but water.
If its clear of oil... breath deeply, and slightly squeeze your bellows. See if it feels like its occupied with something other than air....
Gear oil is nasty stuff.. if its in your bilge it left remnants. Especially around the grill of your bilge pump.
Curiously, your bellows will "hold" a bit over two quarts of fluid. If i were guessing about "missing drive oil"......
