IN HULL TRANSDUCER
did any one install an in hull transducer on their rinker if so are depth readings accurate ?
  • Lake_BumLake_Bum Member Posts: 1,122 ✭✭✭✭
    Before I installed mine, I did very extensive research of not just Rinkers, but all installs in general.  A transom mounted transducer gives much better readings, when properly installed.
    I've installed transom mounted transducers on I believe 6 different boats, and only had an issue once, with an interfering signal from the factory depth finder.  Beams were crossing each others path, and causing wacky readings.
  • IanIan Member Posts: 3,024 ✭✭✭✭
    Based on advice from Lowrance I installed my transom mount port rear corner to get way from the existing through hull and the drives. Works well. Newer units are also a different frequency and so less prone to interference.
