1988 capri. Power steering squeals.
I have replaced the belt, fluid level is ok. Still squeals. Please help, the 4.3 runs great. Also, could I just disengage the pump?
  • WillhoundWillhound Posts: 4,241 ✭✭✭✭✭
    edited August 2020
    Could be the bearing on the pump pulley or the idler wheel bearing. Both easy fixes. Not easy to "disengage" the pump. You'd have to remove it but then your serpentine belt won't fit.
    You can place another idler pulley where the pump is...
    Or
    Heads up: the pump doesn't differ from an automotive one... automotive a boat unit less in $$$.
