How to coax out a few more RPM
davidbrooks
Member Posts: 1,428 ✭✭✭✭
Now that i have the smartcraft gateway connected i have a ton of information at my fingertips. It is almost a little overwhelming. I am trying to figure out the best way to coax out a few more RPMs from the old gal without doing any major surgery so fire away with ideas. Just as background i have an 03 342 with MAG MPI 350's. The serial number has them as a 2002 vintage. I am running with Hill 4x4 22P Props. Inline fuel filters were changed and according to Mercruiser i dont have the cool fuel module to worry about so at most i might have a screen on the pump itself.
Rotor, Cap, wires and plugs were replace June of 2017. I opened the distrib cap and cleaned off the contacts with emory paper. They didn't look worn or corroded at all though.
Currently at WOT i can get up to 4300 on Port and 4050 on Starboard engines and i am maxing out at 36 mph. This is with 2 people, FULL fuel tanks and empty bilge and water. I ordered some new plugs but i put in the NGK Iridium ones that should last longer than 3 yrs and 170 hrs. Watching it suck fuel at WOT was interesting. Each engine was reading 18.7 GPH. That is a thirsty girl. I am cruising at 30 mph at 4000 RPMs. The one thing i was thinking was that my throttle cables seemed to have very little impact from about 80% to full forward. Is there an adjustment on the cables that i should tweak?
My motors both max out at between 5000-5100rpm whilst on plane but when attempting to plane my starboard motor is about 200rpm behind the port motor. I’m hoping a new cap and rotor solves the issue.
Little off topic, but MT would be proud. Pulling out of Kent narrows yesterday, with my buddy in his 400 in front of me. Very busy area at times and lots of current flow. Well, we had a mid 35ish footer SeaRay behind me but not happy with our 6 or 7 mph speed thru the slow zone. He went out of his way under the bridge and tried to get around me and then got squeezed in the channel, right up on my swim platform. My buddy radioed to me to pull in front of him to get on plane first and he'd follow (I tend to be his GPS). Well, as I did that, the SR pulled up with me. I told my son, these SR guys just don't think we are fast enough, just wait. He got beside me while I got up on plane. I shocked him with my 6 seconds to 35mph!! Then about 1 minute later my buddy blew past him as well! Sure was a great feeling. Then he tried to follow in our wake, but he slowly drifted back!
Oh, and then on my way into my home river a guy was crossing off my side, & went up to about 90% throttle to get across quickly. I looked down and literally in a couple seconds at most, I was up to 41mph!! Only saw 4350 rpm and slowed back down! I'm gonna need to take her back up and see how she does at open throttle. I think I've worn down some of my paint bottom now and maybe can get 45mph again!
Oh, and then the admiral commented "you know, that trawler you want some day...you're not going to be able to do that!"
got me thinking with his suggestion to check the shift cable. Just trying to see what else i may need to check out.
For those of yall wanting just a little more push throughout the range, roller rockers respond well on these engines... not because of higher lift or slightly increased duration, but because of reducing parasitic drag on the engine. Most these engines run 1.5:1 ratio stamped rockers... bumping to 1.6:1 will bump into vortec maximum head flow and bump power maybe a point... but the rollers allowing for less drag will bump another 5 to 8%... and throughout the band... from off idle all the way to WOT... cost? $300ish... time? 2 or so hours including tuning them (lash)... worth it? Up to you.
You'll want the pedestal variety, not the ones requiring guides. No more than 1.65:1... 1.6:1 is best... the head flow on vortec heads maxes out somewhere between those two ratios with the cam profile mercury uses most often, ive read.
Take off valve covers, unbolt a rocker, replace it with new rocker... go to next one... go to other side do same... tighten them to 20# I think it is, and loosen them a turn. Place cover on far valves but not bolted down... get a towel ready... fire up engine and adjust the lash by ear (no clanking). Go to other side do same... when you're done all should sound smooth as silk.. tidy up. Enjoy.
Its NOT that this is a power adder, per say, its that it frees up the resistance added by stamped rockers. It does add a little power, but the loss of the parasitic draw is its real benefit. The engine will rev smoother and faster, adding noticeable oomph throughout the range. You'll likely add as much as 250 to 350rpm to your WOT, and, you'll get there noticeably faster.
I used to have an aggressive cam with solid lifters and rockers, she ran pretty well in my old street rod. That engine went in my old man's boat to buy me a crate motor. I do miss that motor sometimes.
https://www.hardin-marine.com/p-27048-ultra-gold-roller-rocker-arms-big-block-chevy-716-17-ratio.aspx
You'd free up roughly the same amount of torque translated to power, but, that would be a smaller percentage with the big block and you'd not feel the push like you would with a small block.
You'd still increase throttle response and step up your rev, though... just like with the small block.
I did it to a diesel as a for instance... it was peaking at 1187# of tq prior.... i didn't even notice them because the tq was so immense prior... but i did notice a particular metal count drop out of my oil analysis and to the point Blackstone pointed it out.... meaning the friction/wear was tremendously reduced.
Its just a real simple and fairly cheap way of getting more out of what you have... stay close with ratios so as not to cause funky geometry issues (a pushrod hitting the sides of its journal on the head or a valve smacking piston).... stay under 1.65:1 and that won't be an issue... max valve lift would still be under 505 or so... with 1.7+ you'd be nearing 515 to 525 and will possibly have inference problems. And.. you'd be surpassing the heads flow rate anyway, which causes turbulence/flow issues and may hurt more than help. The 'game' here is to eliminate parasitic loss of power, not really add anything...
Anything being driven off the crank that doesn't translate directly to the gearbox is waste- somebody mentioned one engine revving lower than the other... my question is of the power steering pump on the slower engine is the one being used? Or if an alternator on one is being used and not the other? Those are parasitic drags and directly off the crank where its easiest to sap its energy (before mechanical leverage)... its the same thing the roller rockers addresses- simply making it easier for the engine to provide power to where you want it by not wasting it somewhere else.
Roller rockers are the "low hamging fruit" of that class of sappers. Easy. Cheap. Beneficial.
My mercruiser built 357 4bbl vortec is running 1.65:1 rollers.... but that is only because that is what I had on the shelf... they are pedestal mounted self aligning (the rollers braces extend past the bearing disallowing them to roll off)... stay away from those requiring guides or shafts and you'll be fine.
Those big blocks MAY have shafts already, which makes this simple simple job more complex and likely not worth it.
You want to slightly (or better said firmly) seat the pushrod into the lifter... holding it firmly but not compressing it noticeably... you simply can't do that unless the lifter is charged... the only way to ensure the lifter is charged is to run the engine.
It sounds scary or at least worrisome... it isnt. Turning the rockers to torque and moving to next one just about ensures they're TOO tight... youll be loosening them until they start to clack a bit, then reversing and tightening until they dont, then add an 1/8th turn... done... youll have the valve covers off and oil will be flying (not that bad) while you do this... this process will take perhaps 3 minutes per side. If you got the locking style caps (you probably should get them though they add stack height) add a minute per side...
You'll be amazed how easy it is, but how impressed your uninitiated friends will be when you explain it to them. Their really isn't much to it.... its the king of bolt on power adders and definitely the low hanging fruit of most engine mods you can do. Easier than headers by a far cry... easier than undersized pulleys... easier than port matching... and applicable for boat engines where those others aren't (except for port matching and bowl blending, but that is a decided move toward more advanced).
