Mercury XR6 outboard help
I’m fishing with my son and we are several miles from the ramp. Once I got on plane and sped up I got a contstant alarm, so I shut it down. I checked the oil reservoir on the top of the motor and it was completely full. Googling looks like it could be an overheat.
I had 15 psi of water pressure going across the lake. I started it and the tone was gone. I can drive for a minute or so and the tone goes off again (steady tone), which really seems like an overheat. Can you have good water psi and not have enough volume to cool the engine?
Post edited by 69fastback on
have you sucked up some sand or other debris lately?
the oil may be full but the sensor may be faulting or gummed up.
temperature is one thing to cause steady alarm, as is oil pressure and an engine knock.. i don't think you have an engine knock sensor on that engine.
the easiest thing to do is get a scanner on it. i know that's not what you want to hear, but... it may be required.
i was thinking it was newer..
