Amp location
LoveBoat2LoveBoat2 Member Posts: 3 ✭
Can't find the amplifier on my 2015 Captiva 276 BR.  5 of 9 speakers are inop.
Best Answer
  • aero3113aero3113 Member Posts: 9,924 ✭✭✭✭✭
    Did they all go out at once? Try moving a bad speaker to a know good location an see if it works.
    Mine was same spot. Hull side, under sink. Back wall of the locker compartment comes out. Had some connectors go loose on the amp - same as JoeStang.
    Hopefully you don't have a fridge. I know some of the newer 276's had a fridge as an option. Be a bugger if you have to remove all that.
  • LoveBoat2LoveBoat2 Member Posts: 3 ✭
    Thanks JoeStang & Mattie - found amp where you said it would be and that the 4 channel connector panel was corroded - unknown water source but clearly reason speakers inop.
