Vessel view mobile gph suddenly way off
Spyderweb
Member Posts: 960 ✭✭✭
Installed VVM last year and love it. I particularly track gallons per hour (gph) to get an idea of efficiency. Typically on plane with twins I am burning around 24-25 gph. At startup maybe 4, and as it warms up 2.
Today I started up at dock and noticed 5 gph per engine. That got my attention. Engines sounded normal. When up on plane, it jumped to around 50 per engine, or about 100 gph. When I arrived at my destination, I checked my gallons left in fuel tank according to VVM and it was consistent with about 1 mpg, not the 100 gph rate. I had burned about 5 gallons in 5 miles.
So, engines seem fine, VVM showing real-time gph about 4 times too high. Could it have switched to liters? The “volume units” says it’s on “gallons”, not “liters” or “imperials gallons”.
Any ideas what happened here?
I use iPad for screen, but I happened to download program on wife’s iPhone last summer but never used it. Just opened VVM on her phone now and it automatically downloaded “something”. Likely the update? Compared version to what’s on the iPad and they match- 1.11.0.1i.
Going home this morning. Will try firing up and toggle and see if it self corrects.
Just started up engines and still reading high and labeled as GPH. Went into settings and changed to liters per hour. Still read the same number (3.5) but labeled as “liters per hour. Changed setting to imperial gallons. Still read same number (3.5) but labeled as “imperial gallons”. Changed setting to gallons per hour. Still read same number (3.5) but labled as “gallons per hour. It’s as if the settings change, but the number doesn’t to match the label. However, each time I change the measurement, the gallons of gas left in tank number does change to the appropriate number (gallon, imperial gallons, liters).
No time now, but I suspect next step (barring hearing something else) is to try a “reset”. Perhaps should contact the VVM people from home and see what they say.
I have version 1.11.1.0i installed on iPad, prior version from last week was 1.11.0
In my years of being involved in software development reviews and the outcome I am still amazed how some of the most minor functional tests and regression validation gets overlooked an things like this get out there.
