Not that it matters which boat, I also have the 400, but any boat that is not plugged into shorepower will need the generator to have 110V at the outlets. If you need to power some small items, you could properly install an inverter.
I need to run a bunch of rope light and two guitar amps for a boat parade so my 2000 watt invert should do the trick BUT that is a lot of inverter. What does the generator put out?
If it's the same as mine, it is a 7.3kw, which should be enough to do the trick. Just note you are limited at the outlets by the breakers and the GFI (which is on the outlet in the V-berth for the port side). Sounds like a good time! I don't think i would try to run all that on an inverter.
Here is another way to have 110 volts while at anchor or cruising slow. I bought a new 2000i honda generator. It's powerfully enough to run the a.c. and almost anything else I have aboard ( but not all at the same time) it has an exhaust extension, and a 30 amps extension cord that plug into the ac or shore power connection on the side of the boat .it his so quiet . But be carefully with carbon monoxide I did install a detector close to it just in case
Paul
