Dexcool and mercruiser antifreeze compatibility?
PickleRick
Member Posts: 4,373 ✭✭✭✭✭
I don't have many marine shops local, none i can go to without taking a 2 hr lunch break anyway.
Its near the end of the season so im stocking up on service items that may have been neglected in past.
First up is draining the closed loop system and flusing with fresh.
While I will be able to get most of the coolant out, I won't be able to get it all.
I plan to switch to dexcool as i heard it was compatible with the current mercrusier coolant that has been used. Can anyone else confirm this? I dont want to rely on googled results from a few other forums. If it won't, what other coolant is compatible with mercrusier coolant?
Says it right on the amazon listing.. sure looks the same!!
Seeing as how I need FIVE of these after changing the risers, looking for a deal on it as well. See one on walmart.com for 18 each...
If you've got the orange stuff in your current system then any brand labeled "DexCool" is compatible. I got the Prestone 50/50 ready to use version from O'Reilly's for $17/gallon.
Looks like they have a sale right now...
https://www.oreillyauto.com/detail/b/prestone-2761/cooling---heating-16773/thermostats-and-gaskets-16977/engine-coolant-antifreeze---vehicle-specific-13547/5c8bd1ce1fcc/prestone-1-gallon-orange-50-50-coolant-antifreeze/af850/2496966?q=dexcool&pos=9
I would prefer to use local
A: commercial discount at orileys
B: they deliver to me
C: half the cost of merc
Thanks guys!
https://www.hardin-marine.com/p-109654-anti-freeze-92-877770k1.aspx
And they also label it as: "DEX-COOL compatible"
And yes can pick on them, its hard to find good help.
