IAC position
noidea44
Member Posts: 15 ✭
My 246 is having some issues starting. It stalls when trying to start but if you give it gas she’ll start.
fuel pressure is at 43 lb, IAC filter is pretty clean but the inside of the IAC has some corrosion.
It not throwing any codes on the Rinda. I am thinking it’s the IAC motor. With the key on the IAC position is 10 and running is around 60. Are these parameters normal?
I should also add, in the past, when I turned the engine off you would hear a slight hiss/air sound near the IAC and now I don’t.
