help to remove cockpit drawer
oscar1oscar1 Member Posts: 803 ✭✭✭
any one know how to remove the following drawer from her track. thx
  • TonyG13TonyG13 Member Posts: 1,425 ✭✭✭✭
    edited September 2020
    It's fairly straight forward. There are screws on the inside bottom of the seat which attach to the rails on the underside. Remove your stuff that's stored in it and you'll see them. Just unlatch the slide-out from the bolt, allow it to extend fully, then unscrew them and it will slide/lift off. It is a bit heavy. Any particular reason you need to remove it? You'll basically have access to the port fuel tank sender area.
