Shower cubicle leak 280ec
Every time we use the shower we end up with wet carpet all along the front edge of the cubicle. I've checked the usual things: forward bilge dry, no leaks from shower sump, pump, or associated pipework. I notice that the front of the cubicle appears to be a separate part attached to the rest of the cubicle and there is a joint all along the front edge of the cubicle, below the door and just above the drain hole. Could that joint be leaking? Has anyone had a problem with that? Or does anyone have any other suggestions where I should start to look for cause of the leak?
Nick Wight.
  • Pat310Pat310 Member Posts: 606 ✭✭✭
    Check the door seal. Mine was pulling away
    I randomly read yesterday about someone else having this exact issue on here, different Rinker though. I believe their issue was the floor drain wasn't sealed into the floor anymore so water was getting past the drain and down below the shower.
    The door seal or the floor drain. I would check those two first.
  • NickWightNickWight Member Posts: 30 ✭✭
    Thanks for all of your responses and I'll look into the problem further when I'm back at the boat on Monday.
