Water level in bilge
How deep should the water get before the bilge pump kicks on? I got some rain water in the bottom this past week and decided it was time to clean it out good. I figured I would dump a couple buckets of fresh water in and let it pump it out and then wipe of the remaining with a couple towels.
Well, I got 6 buckets in and the pump was half covered with no activity. I turned the bilge pump on manually and it started humming, but it didnt seem like it was moving any water at all. I had probably close to 4" of water under the engine, so I expected it to pump that out.
So, I gave up and vacuumed the water out with a shop vac I keep on board, but that was a pretty big PITA. Good thing I have an understanding wife!
So, does it sound like something is wrong, or am I expecting the pump to kick on too early? I cant imagine wanting anything close to the amount of water it allowed.........
2013 276 Cuddy ~ 350 MAG / B3
Jtkz, I don't know which boat you have but on our 342 back in '06 I installed a secondary pump in the ER space. It is a bit above the standard pump. I lift the levers occasionally to hear the pumps come on just to verify all is well. I suppose I should put a secondary pump in the forward bilge but there are far less reasons for a catastrophic water inlet failure there. Still it would make sense to double protect that area too.
Anyway my point is there is no level of bilge pump capacity that is too much IMHO.
Tony
Salt Shaker 342
So, maybe I didnt get the water quite 3" high, but it still should have pumped it out when I turned it on manually.
Now, I MAY have had a tiny bit of oil in the water (just changed the oil), and the pump is designed to only operate when it senses water. So I wonder if the tiny amount of oil caused it to think it shouldnt pump it out??
I dunno, after readings TONS of negative reviews on the 500A I am really anxious to make sure it works correctly, but my bilge is normally bone-dry, so I'll have to literally put a garden hose in there and fill up 3"+ of water to get it to turn on......
