No power to ignition 270
So today my Rinker 270 started fine and then died and now there’s no power to the ignition switch or the radio but everything else powers fine. It seems like there’s a main fuse somewhere that I just can’t find. Any help would be appreciated. It’s acting like the Killswitch is pulled but that’s not it
    There's a main fuse at the engine block. Some years used a resettable breaker, others a fuse. Should be under the spark arrestor towards the rear of the block I believe.
    Thanks Will. I did look all over for that but I will check again
    @Willhound he has Volvo not the same as merc but must be a circuit breaker.
    Ahh. Did not realize that, sorry @luvinlife didn't realize it was Volvo.
    There is relays and fuses on the top of the Volvo. Maybe one went bad
