2003 5.0 rinker 312
monstermonster Member Posts: 7 ✭
2003 twin 5.0 so my starboard engine went filled with h2o  port engine compression engine still ok. one cylinder compression read 130 others on port read 140 and 135 I think brand new compression should be at 175. if you know what compression should be chime in please. starboard transom leaking slightly. port ok. but the boat is raw water cooled and 18 years in salt h20. original aluminum gas tanks. If gas tanks are advised what gas tank would you recommend. do you see where I'm going with this? here is my question and I'm seeking advice.  does mercury repower the 5.0 engine? if not will the 350 be able to mount in my boat in the same place and fit?  also pricing if you know. thank you in advance
