Rinker Parts
DonGarganoDonGargano Member Posts: 60 ✭
In addition to a few other minor issues, I don't think the fuel gauge on our 96 Festiva 212 is reliable.  I am using Great Lakes Skipper to find parts..but often strike out. Any thoughts?
    Do you think the problem is with the gauge, or the sender in the fuel tank?  The sender is probably from ISSPRO (www.isspro.com).
  • DonGarganoDonGargano Member Posts: 60 ✭
    not really sure yet.  Picked up boat this spring...marina mechanic took a look at wiring, tested it, and said it should be OK.  Maybe my expectations are too high.  Should I expect the gauge to fluctuate while underway?
    makes sense that the tank would indicate fuller when under way because the bow is higher
    Some gauges only read to the nearest 1/8 tank.  Instead of dropping slowly as you use fuel, it will read 3/4, then suddenly drop to 5/8.  You can check this next time you fill the tank.  Either watch the gauge, or set up a cell phone to take time-lapse video.
    If the the gauge is randomly going to zero and back, I'd guess it's a gauge issue.  You might check the plugs on the back of the gauge, and/or the wire connections at the sender.
    never as bad as zero and back, but it does seem to jump all a sudden from full to 3/4 etc. Like the idea of monitoring and timing.  Thanks
    One last thing, any idea where the sender unit would be on a 1996 212 Cuddy
    On the tank. Looks something like this
    Moeller Marine Electric Fuel Sending Units
  • IanIan Member Posts: 3,067 ✭✭✭✭✭
    edited November 2020
    Any idea of the depth of your tank? I have a 17” sender available for sale if you need a new one.
    https://rinkerboats.vanillacommunities.com/discussion/11857/kus-fuel-sender-unit#latest
    I  also have two senders for sale that are adjustable.  I can post make/model if needed (I can't remember off hand).
  • BobtBobt Member Posts: 1 ✭
    I have a 2001 232 captiva bow rider and I need a new 75 gal fuel tank. Any idea where I can buy one?
    Hey @Bobtwelcome to the forum.  You should post this as a separate topic to make sure more people see it.  First stop, check www.greatlakesskipper.com
