I have a 270 FV and have air conditioning problem
NickCruz
Member Posts: 81 ✭
I just got the boat, a fixer upper. I got most items working but the air conditioning does not have water and I am not sure where the plumbing is for it. Or the pump and filter. Can anyone help. Thanks
Best Answers
laureniac1 Member Posts: 263 ✭✭✭
Underneath mattress in aft cabin. Lift up mattress right behind steps and you will see a white access panel -
Aqua_Aura
Member Posts: 2,705 ✭✭✭✭✭
Does not have water? Are you saying the boat is in the water and the a/c is not pumping? The valve under the mattress could be turned off, beyond that the pump could be bad or the strainer under the mattress could be clogged as well.1997 Bayliner 3988
where is this boat nickcruz
gotta put it in the water
but on the ac it does need to be in the water and primed
funny i boat on table rock and there's a nick cruz at the marina
Strainer bowl should be clearer. Old pictures from when I got the boat
not being a sa = dont be scared to use the search
on my 2004 270 the AC water pump is in the compartment in the aft cabin as previously noted and is attached on the forward port side wall of the compartment up high
you almost have to stick your head right in there to see it.
