Forward bilge pump
I have a 2003 fiesta vee 410
does anyone know where the forward bilge pump is located?
  • rasburyrasbury Member Posts: 8,986 ✭✭✭✭✭
    should be under your rear birth somewhere?
  • goalie59goalie59 Member Posts: 356 ✭✭✭
    Hi tthom, I'm not sure that there is one. I purchased an 05 in the fall and have not found one yet. There is a cavity under the rear birth but there is not a bilge pump in it . The through hull if there for the ac , shower sump and fresh water pump. Maybe Al will chime in after all he designed the boat.
    It's usually located just forward of the engine room bulkhead (within 2-3 feet).
    At the helm, turn on the bilge override switch, then go into the cabin and start digging.  You should be able to hear the pump.
