Battery Relay Switches
aero3113
Member Posts: 10,056 ✭✭✭✭✭
aero3113
On my boat, each starter battery has a fat cable from the battery up to that 12V panel near the transom door -- a distance of about four feet. Those wires are always hot. If there's a short-circuit anywhere along that length, turning off the battery switch does not disconnect power to the short.
With relays, the cutoff is right next to the battery. The switch up at the panel is just a remote control for the cutoff. Set the relays on "auto" and use the panel switches to disconnect the batteries.
I wish I had thought to install relays when I rewired my boat. It's a safer setup.
