shaking in reverse
JPJonesJPJones Member Posts: 12 ✭✭
Wondering of anyone has dealt with this one--am getting some shaking and rattling in transom area when in reverse and turning.   My first guess is possible loose linkage in the steering arm assembly.  Have to confess until I have someone with me to drive while I watch the steering arm up close I can't tell if its the steering or something else. Engine mounts, power steering and drives seem to be okay.
Post edited by JPJones on
  • raybo3raybo3 Administrator Posts: 5,589 admin
    Have you hit anything????? Maybe a bent prop or some line tangled in them....
    Oh does that sound like XDP drives eating their gimbals up.  If you have these drives, that might just be it.  The original bellows design and a couple of redesigns after that would wear thru and allow water to get in there and corrode the gimbals.  Could this be what is going on?
    Tony
    Salt Shaker 342
    edited August 2013
    Sounded like Gimbals to me to but I didn't want to be the 1st one to break the bad news
    Hi Boomer,  I thought I should be the one to suggest it because this same thing happened to me, as you know.  Painful
    And JP, I might have had a ride on your boat in '06.  I lived in GA at the time and was becoming interested in boating.  There was a dealer who had a Rinker account right near Lake Lanier.  I forgot the name of the dealership.  But I was in contact with him, looked at a 320 and a 342 that he had blocked up under his shed roof in the front.  At least that is how I remember it.  I arranged with him for a test ride on the lake in the 320.  That was a great ride.  I really liked the boat.  I said to my self, if I can work things out financially, I this would a good reason to do so.  So yours could have been the one.
    Tony
    Salt Shaker 342
  • JPJonesJPJones Member Posts: 12 ✭✭
    Will be taking another look although the drives were pulled and serviced in March by Volvo dealer-- inspected, lubed,  bellows replaced, gear lube, props reconditioned, etc.  All these moving parts on a stern drive boat are enough to drive one to inboards!
    edited August 2013
    I know, two engines and two outdrives is kinda like having four engines to service and keep track of.
    I hope your vibration problems are not related to the XDP drives and they very well may be from something else.
    Yours is a very benign fresh water environment so that is a big plus.  Our boat is run hard (meaning often and on trips) in a very rough salt water environment so we would expect to encounter the effects of XDP design problems before most.  And we did.
    But with a lot of TLC to these drives we were able to get 900 hours and 7 years out of them before we threw in the towel.  I am hoping our new OceanX drives will be trouble free.  They sure made the Salt Shaker into a different boat.  I am thinking of changing the name to "Jackrabbit."  LOL
    Tony
