Refrigerators
Both my refrigerators are not working one not at all the other just barely. Any ideas much appreciated.
    Depending on age, you might be able to get basic parts like a thermostat.  If compressor/leak issues cost to fix might exceed cost of new.
  • YYZRCYYZRC Member Posts: 5,495 ✭✭✭✭✭
    Is the compressor running? Can you feel a temp difference between the lines? @Handymans342 might have other ideas.
    I had to replace the thermostat on one of mine.
    Are they on shore power or batteries? Maybe the batteries are low...... just a thought
    How long have they been like that, unusual for both to go down at the same time. Sounds like a power supply problem.
  • BfieldBfield Member Posts: 3 ✭
    Sounds like they may be low on refrigerant must have leaks
