Location for Hole for Transducer Cable
fclemente
Member Posts: 2 ✭
I have a 2006 Captiva Bowrider and want to add a transom mounted transducer. The hole location is tricky as the inside looks slightly different than the outside. Does anyone have pictures of ones they may have done? The years 2004 thru 2009 were all very similar. Thanks in advance.
Run the wire up above the water line and use a clam shell type cover (red circle) and fill it with 4200. Make sure any cable holders have plenty of 4200 in the screw holes. Never fun drilling holes in your boat. Hope this helps.
https://www.amazon.com/dp/B00L4GGI9Q/ref=cm_sw_em_r_mt_dp_3DMX29VGW4MVNQN3889X
