Help finding capacitor
Liberty44140
Member Posts: 4,414 ✭✭✭✭✭
I posted months ago that twice last fall, my cockpit ac breaker flipped while running the boat with heat on. Salon all good. Once flipped back, good all day. I replaced the breaker over the winter as that’s an easy troubleshoot but I’d like to replace the capacitor too. This unit is in constant high heat heat, and is not used often….two things bad for a capacitor. Also it is very easy to get to for a pro active fix. But….. I can’t find a replacement!
here it is, any ideas on a replacement?
https://www.ebay.com/itm/ROUND-CAPACITOR-370-VAC-50-60-HZ-CSC-NEW-/373093218305?_trksid=p2349624.m46890.l49286
https://www.ebay.com/itm/RUN-CAPACITOR-30-MF-370-VAC-50-60-HZ-CSC-/273383382330?_trksid=p2349624.m46890.l49286
https://www.google.com/search?q=Hqrp+30uF+370v+Run+Capacitor+AC+Electric+Motor+Start+Hvac+Blower+Compressor+Pump+30mfd+Cbb65+plus+Hqrp+Coaster&hl=en-US&stick=H4sIAAAAAAAAAONgVuLVT9c3NMwwLEgyNzc1fsRowS3w8sc9YSn9SWtOXmPU5OIKzsgvd80rySypFJLmYoOyBKX4uVB18vxiFAjILyjNSSxSKCjKTylNLinuYGVaxJrnUVhUoGBsUOqmYGxuUKYQVJqn4JxYkJicWZJfpODorOCak5pcUpSZrOCbDxIJLkksKlHwKEtMVnDKyS9PLVJwzs8tKEotLgZKBpTmgszKTUtRcE5KMjNVKMgpLVYA2-Ccn1hcklp0gLVn7a7zrV1XuiIOsO7YcHbG8psX73xiPMB659fVr18OLPqYcYD1zJYPLzs7dj6IPsB6aM2v6xu3fOk-C1Qx6f_cjo6zi67sALL3tr19fXbZhnNbgOwvq6a9bZp_d1vlAdbbT1svv1vWN83jAGvvgcUrXn791sF2i02SQWtqFVdq9rfP-6RuN_p6_cg7sNpWdHesQw4A4aTYg2EBAAA&sa=X&ved=2ahUKEwiw07vuwLHwAhVSds0KHb6zDkAQlr4CegQIIBAN&biw=1024&bih=653
Maybe this will get you in the right direction
https://www.amazon.com/dp/B0753YGNGB/ref=cm_sw_r_cp_apa_glt_fabc_T3DK3YGR3RE8P073EE14?_encoding=UTF8&psc=1
https://askinglot.com/can-you-replace-a-capacitor-with-a-higher-uf
Luckily it's nothing fancy like say a flux capacitror
