Water pump malfunction on our 3 year old Rinker 340 with Mercruiser 350 mags
OldDogNewTrix
Member Posts: 166 ✭✭✭
Last winter our marina tech noticed that the starboard water pump needed replacing and they did that during the winter maintenance. Yesterday, in the middle of our 2 week vacation, the engine alarm sounded as we were on plane 15 minutes out of Gananoque on our way to Picton then Bellevile ( MT, you'll know this area exactly). I shut down both engines, then read the code on the Vesselview, the port engine had overheated, sure enough, it was at 200 degrees! Luckily I was in a large area of open water in the main channel south of Wolfe Island so I popped the engine hatch and had a look. Right away I noticed the serpentine belt lying in the bilge. First thought was oh great, I have the spare one from last winter when they put a new one on the starboard engine. Once down there, I realized it seemed to be OK so I began to put it back on. Figured out how the tensioner functioned and continued. However, once it was on, I realized that the pulley on the water pump was out of line with the other pullies. There was no way to tighten it so back to Gordon Marine in Gan on one engine, luckily the one with power steering. Technician there was vey helpful, knew exactly the problem. Apparently this is very common with this engine. Luckily I have the extended warranty so all costs are covered. He was able to get one in overnight and I saw the courier arrive at 6:45 this morning with it. The only downside was that they could not get it installed until Monday so we're here in Gan for 3 days. Had a front row seat for the poker run and we're enjoying the town. Hopefully we'll be back on our way Monday afternoon. The tech mentioned that next time, in 3 years or so, and near the end of our warranty, to get an aftermarket water pump that it designed to not do this. I'm not sure the details but am disappointed these engines are susceptible to this malfunction. In the end, we changed our trip plans and are still on the water enjoying the boat!
Wayne
'09 340 EC
And, you want this to happen...
The alternative is a pump with worn blades that doesn't move neither the volume or the pressure needed to consistently cool and engine.. when the blades wear, it makes enough wiggle to unseat that bushing and spray your hold.. announcing, basically, that its time for a new pump..
I've seen engines overheat w/o obvious reason... Everything in the world done to try to figure it out, and finally pulling the pump just to find pencil thin spinners, stubborn bushings and weep passages, and because the design (which is maybe by design, maybe not, and another conversation either way) didn't perform like it should announcing its imminent failure.
Edit: my phone is funny.. it changed mis-aligned to malign.. I'm not certain the two could logically be used in the stead of the other in any circumstance.. :-)
