414poplarct ✭ I have a 2007 Rinker 360 having problems with engine hatch it will not go up
414poplarct
Member Posts: 30 ✭
414poplarct ✭
I have a 2007 Rinker 360 having problems with engine hatch it will not go up. I did get it to go up with with the bypass. Checked all battery's and wiring. Besides the 2 battery switches to the right of the stern is there any other switches that need to be on. This boat is new to me just got it last fall and it was working then. Also the blower will not go on. I did change all the instrument gages and replaced the freezer. If you can please respond to my email address fryz89@gmail.com
Best Answer
LaRea
Member, Moderator Posts: 8,082 mod
For the hatch, turn on the battery switches and the helm power switch.
The blowers have circuit breakers at the battery switch panel. Look for a push-to-reset button. Also, check the connections at the top of the fire extinguisher in the engine room. The fire suppression system is designed to disconnect the blowers in case of a fire.
Here's a summary of Mercruiser alarm codes.
Thank you everyone
