Lenco control box location
benvenuttioki
Member Posts: 131 ✭✭
Can anyone tell me where the Lenco Auto Glide control box might be on 370 (2017)? Tried tracing harness down from keypad, but ran into a rat’s nest of wires about elbow-length deeper. My key pad stopped turning on with ignition. Voltage on keypad connection is only 1.4 V, and Lenco tech support suspects control box problem.
Reinstalled last weekend and tried to go into test mode. No response from keypad. Set up call for today w/ tech rep.
Got to boat last Fri night, flipped key to aux for radio, and keypad lights up. Huh.
Sat morning, went into test mode, completed roll calibration, and it transitioned correctly to pitch cal. While running, at end of pitch cal, all lights went out and pad was unresponsive again.
Over the next couple of days there were a series of dead keypad, responsive/cal attempt, dead again.
Today, Lenco rep had me check power at connector to keypad (it’s in dead state). Should be ~ 12V w/ engine running. It was 1.2V. Tech said to chase red and black upstream from keypad, which is an exercise in frustration.
Tabs came up in cal mode, completed cal, and worked properly on trip Sat & Sun.
On the trip home Sun, plotter repeatedly rebooted and finally shut down entirely while VHF constantly turned off and on
This should be fun to chase down. Not.
