Removing 342 galley refrigerator?
rmfridayrmfriday Member Posts: 106 ✭✭
Has anyone removed their 342 galley fridge?
ours quit working and it seams the compressor is locked up, after some quick measurements it seams it might be a issue getting out the door?
    Very easy. There are around 8 screws on the flange on all 4 sides. Pull those screws and then pull the fridge out. Nothing to it…
  • raybo3raybo3 Administrator Posts: 5,619 admin
    Are you talking about removing it from the cabin? I dont think it can be done easily. IMO your best bet is to get an refrigeration guy there and have him fix it. He can replace the compressor if that is the problem. Good luck with this one and keep us posted.
    I had to remove the trim around my sliding door
  • rmfridayrmfriday Member Posts: 106 ✭✭
    Thanks Handy, Raybo good idea, i will see if i can find someone locally to look at it.
    Thanks,
