Inspect or replace?
davidbrooksdavidbrooks Member Posts: 1,432 ✭✭✭✭
I am at the 5 yr mark for exhaust manifolds and elbows.  I dont have any indication of corrosion or that they are restricting water flow but i know that general practice is to replace them at 5 yrs.  The Chesapeake is not very salty so i am just wondering what everyone has done.  I am definitely looking to do this my self as it seems about as straight forward as can be.  I was just thinking if anyone just ordered a gasket kit to to pull off the elbows to inspect them instead of just replacing?  I don't have risers and do have a closed freshwater cooling system.  I have seen such a big price difference also.  Anywhere from $850 an engine to twice that.  Any benefit of one over the other?
    I'd take one off for inspection.  My risers have been used for 6 years/230 hours in the upper Chesapeake, and 9 years/600 hours in the Potomac (fresh water).  They look almost new.
    You can also check your water pressure.  If it is reading around 20psi, then you don't have much clogging creating back pressure.  If it is upper 30's then it is time.  I just did mine and a friend has one that is touching the 40 mark, time for him too. Mine were 13 years old.
    @Dream_Inn that is good to know.  I will have to look at that and see if i can get that reading from the gateway.  Where did you get yours from and what was the cost?
    I get mine on VesselView, but you should be able to get it from gateway.
    Sorry. I meant where did you get the elbows and exhaust manifolds from and what was the price.
    oh, I had Rhode River do mine.  I can't remember exactly how much (probably a good thing), but I can look up the bill.
    @Dream_Inn I tried to add in the water pressure this weekend.  No luck.  The closest reading i could find was Coolant Pressure.  I guess i am going to have to crack them open and inspect this fall.
    I did mine after 8 year in salt water in miami, but I flow my motor every time I used the boat.
  • rkinrossrkinross Member Posts: 178 ✭✭
    @oscar1 How do you flow a motor?  A google search indicates it is for electric motors.
    Flush
