1988 Rinker Fiesta Vee 250 wiring questions
bwk9087bwk9087 Member Posts: 9 ✭
Hi, getting close to getting my boat back on the water, motor runs, outdrive works, and am now trying to figure out how a couple things work.
I cannot read the refrigerator sticker, should it run off 12v or just 120 shore power?  I have not hooked shore power up yet, had the wrong adapter, and it does not run on 12v, i have not verified yet if I even have it, without some disassembly it seems.
Interior lights, are they 12v, or 120v or both?   Can't seem to trace those easily either.
Galley pump, I do not have a switch for this, is it automatic, I am assuming by drop in pressure when opening faucet.
I have not been able to find a wiring diagram for my boat either,
thanks
    Fridge:  should be DC and AC.  Look for a circuit breaker at the battery switch panel?
    Cabin lights:  12v DC only.
    Galley pump:  auto-on/off from pressure, but should also have a switch or breaker.
    This set of schematics is from a 2007 280, but it might help you.
  • bwk9087bwk9087 Member Posts: 9 ✭
    Ok, thanks, at least this is what i thought it all was, just have to tear things farther apart to trace wiring.
